Credit for that awesome zero turn mower photo: https://www.gravely.com
Original brain dump.
- How about an accessible robot fighting platform. I'm thinking a loop of polycarbonate and most zero turn mowers become suitable paintball platforms.
- upgrade paths, larger tires for speed, treads for... well cause. smaller and larger calliber or variable fire rate/pattern munitions. Perhaps drone strikes with paintballs..
- play in urban, park, or woods settings. Need some cover. A loading dock might be fun.
- Project a cockpit on your loop of polycarbonate. Add realtime battle data, teams, objectives.
- different classes of mobile platforms setting up virtual defenses projected over the terreain for both parties.
- generate artifical exclusion zones via virtual weapons installations, and countermeasures.
- give the mower a kill switch. When you are hit, you are out. PWM it for various levels of failure/artificial drama.
- hitting the dash works.
- The mowers join a shared master node which coordinates the established exclusion zones. Mesh connectivity and a few repeaters should be enough, if we trust all nodes. We probably shouldn't.
- or just shooting paintballs to start with would be fun. Sustainably though, virtual ammo would be the way to go.
- bfg.
- blinds the cockpit of the user (projector full on) for a few seconds and kills team-mates as well. Hog on charge.
- I need a mower.
- I wonder if you can vacuum deposit the specific wavelengths provided by your projector onto the surface of the polycarbonate... in a spiral, in a tube, from one end. I wonder if you can pull a full vacuum on ABS pipe..
- for reflection, dicromatic style. Or just give it a misting of retroreflective beads and project from above the user.
- It's a great time to be a maker. I could probably pull up at least a few hits on everything I just piled together there.
MasterOfNull
