The mane components came out over 3 days. The motor mounts evolved during printing. The mane regret is how wide the motor mounts had to be to house the board connectors. Surface mount connectors would have been smaller but required expensive ribbon cables.
The motor mounts were properly booleaned so nothing sticks into the bore.
The big piece took 16 hours. No obvious evidence of the gantry sag.
