Put a raspberry pi into a classic iPod (video)
I built a breakout board for the clickwheel connector. This way I was able to probe which pins connect to where on the chip. I posted my results on Github.
The chip on my board has the label "CY8C21434".
If this protocol works the same as the 4th gen, then I should be able to set up the arduino in SPI slave mode to communicate with the wheel.
Previous work:
- https://github.com/Gigahawk/clickwheel_sample_firmware/issues/1
Breakout board
- https://github.com/Gigahawk/clickwheel_breakout_5th_gen
More RE:
- https://github.com/Gigahawk/clickwheel_reverse_eng
View all 2 project logs
Keith
Alan
SHAOS
Stephen Edwards
Yes, delete it Cancel
You are about to report the project "iPod", please tell us the reason.
