POC fans
A project log for Solder Fume Extraction Station Deluxe - from scrap
Inhaling the solder fumes is terrible for the health. Maybe some old parts from my old PCs could supply some details for this project.
debinixDebinix 10/24/2022 at 15:570 Comments
Project notes 2022-10-24 (POC PSU fan)
All my scrap fans are simple 2-wire power-feed 12V fans.
Initial tests rule out old PC fans due to lack of static pressure capability, but the PSU fan looks promising and starts spinning at 2.7V. The electrical current consumption of the latter was 0.46A at startup but throttled down to 210 mA when it's up and running. The Corsair PSU fan is a sturdy unit with metal blades.
The PSU top part metal cover width is 150 mm from the PSU chassis scrap pile. We can later fit some HEPA and active carbon filters there to absorb the bad stuff.
Rich text editor
