A stepper motor gearbox for robots. A setup with planetary gears fits to mobile robots, a setup with wolfrom gears for robot arms.
GearboxWolfrom_V01.zipSTL files of the wolfrom gearbox parts that are printed. You do need four planets.x-zip-compressed - 5.19 MB - 10/22/2022 at 16:47 |
GearboxWolfrom_V01.STEPCAD file of the wolfrom gearboxstep - 6.13 MB - 10/22/2022 at 16:47 |
GearboxPlanetary_V01.zipSTL files of the seven planetary gearbox parts that are printed. You do need four planets.x-zip-compressed - 5.06 MB - 10/22/2022 at 16:30 |
GearboxPlanetary_V01.STEPCAD file of the planetary gearbox, output flange for meccanum wheelstep - 4.55 MB - 10/22/2022 at 16:28 |
With PLA the tolerances were very good in my set up; using PETG was not that good... I adjusted the fit to the bearings by printing with a slight increase in size, defined in the slicer.
