Here's the code I am currently running. The broad structure is:
- Create an open access point for users to connect to;
- Declare the variables needed to control the LED flashing speed etc.
- Create a table with the locations of various additional files needed. See this excellent tutorial here for how to serve up big files. I have copied most of this code but with a few small tweaks.
- Start the PWM on pin 1.
- Loop through all of the submitted data from the HTML form (stored in _GET in this example).
- Use the data to set the PWM value and alarm cycles.
The only slightly strange bit of the codes is the lines that follow this pattern:
partial_data = string.gsub(partial_data,"xxBVxx",ledPWM)
In the HTML files, each of the values for the form inputs is as follows:
<input class="slider-width" type="range" name="Brightness" min="0" max="1023" value="xxBVxx" onChange="form.submit()">
The nodemcu code goes through the HTML source and replaces xxBVxx with the correct PWM value. This ensures that the webpage served up has the sliders in the correct position.--Close any servers already running
if srv then srv:close() srv=nil end
wifi.setmode(wifi.SOFTAP)
cfg={}
cfg.ssid="AlexsXmasLights"
wifi.ap.config(cfg)
--Variables for flashing lights
led1 = 1
ledPWM=500
flashSpeedOn=500
flashSpeedOff=500
glowOn="On"
glowSpeed=5
gpio.mode(led1, gpio.OUTPUT)
value = true
glow=true
scan=true
--Tables for file locations
local httpRequest={}
httpRequest["/"]="mainPage.html";
httpRequest["/index.html"]="mainPage.html";
local getContentType={};
getContentType["/"]="text/html";
getContentType["/index.htm"]="text/html";
local filePos=0;
--Start the PWM stuff at full
pwm.setup(led1,1000,ledPWM);
pwm.start(led1);
tmr.alarm(0, 500, 1, function ()
if(glowSpeed>0)then
if(glow==true)then
ledPWM=ledPWM+1
else
ledPWM=ledPWM-1
end
if(ledPWM==1000)then
glow=false
end
if(ledPWM==1)then
glow=true
end
pwm.setduty(led1,ledPWM);
tmr.interval(0, glowSpeed)
else
value = not value
if(value==true) then
tmr.interval(0, flashSpeedOn)
else
pwm.setduty(led1,0);
tmr.interval(0, flashSpeedOff)
end
end
end)
srv=net.createServer(net.TCP)
srv:listen(80,function(conn)
conn:on("receive", function(client,request)
local buf = "";
scan=false
local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP");
if(method == nil)then
_, _, method, path = string.find(request, "([A-Z]+) (.+) HTTP");
end
local _GET = {}
if (vars ~= nil)then
for k, v in string.gmatch(vars, "(%w+)=(%w+)&*") do
_GET[k] = v
end
end
--Loop through info submitted
for key,value in pairs(_GET) do
if(key=="FlashSpeedOn") then
flashSpeedOn = tonumber(value);
if(flashSpeedOn>0) then
tmr.start(0)
else
tmr.stop(0)
end
end
if(key=="glowSpeed") then
glowSpeed = tonumber(value)
end
if(key=="FlashSpeedOff") then
flashSpeedOff = tonumber(value);
if(flashSpeedOff==0) then
tmr.stop(0)
pwm.setduty(led1,led1023);
end
end
if(key=="Brightness") then
ledPWM = tonumber(value);
end
if(key=="glowOn") then
scan=true
glow=true
end
end
if getContentType[path] then
requestFile=httpRequest[path];
print("[Sending file "..requestFile.."]");
filePos=0;
conn:send("HTTP/1.1 200 OK\r\nContent-Type: "..getContentType[path].."\r\n\r\n");
else
print("[File "..path.." not found]");
conn:send("HTTP/1.1 404 Not Found\r\n\r\n")
conn:close();
collectgarbage();
end
end)
conn:on("sent",function(conn)
local next1 = 0;
if requestFile then
if file.open(requestFile,r) then
file.seek("set",filePos);
local partial_data=file.read(512);
if(partial_data~=nil) then
if (string.len(partial_data)==512) then
next1 = 1
end
partial_data = string.gsub(partial_data,"xxFONVxx",flashSpeedOn)
partial_data = string.gsub(partial_data,"xxFOFFVxx",flashSpeedOff)
partial_data = string.gsub(partial_data,"xxGSxx",glowSpeed)
file.close();
if partial_data then
filePos=filePos+(512-string.len(partial_data))+#partial_data;
print("["..filePos.." bytes sent]");
conn:send(partial_data);
if (next1==1) then
return;
end
end
end
else
print("[Error opening file"..requestFile.."]");
end
end
print("[Connection closed]");
conn:close();
collectgarbage();
end)
end)
