Always seems like forever, but got the PCBs in. They look great. I found a couple issues off the bat. The chips I ordered were the wrong package size. I designed for SOIC and got SOP. Digikey has them listed wrong. And the datasheet only indicates they are different in one small place. There's not even a mechanical drawing of the SOP on it. Anyway, it's still solderable, but it takes more care. Maybe I will update my footprint to be compatible with both.
I also discovered I swapped my MOSI and MISO. Not a huge problem, but now I'll have to bit-bang the SPI since those pins are hardwired. Which makes it slower. If it's a big problem I may cut traces and rewire.
Next up assembly.
