User Connor Huffine started a project using these boards, and I *think* I remember a HAD article touting his project a few years back.
He did a lot of the heavy lifting for this project - figuring out the connector pinouts, tracing the power supply circuitry, and so on.
Then... nothing.
The reason no one's been able to interface with the boards is that they have non-standard connectors. The data connector (shown below) *appears* to be a SCSI-type connector, but with 60-pins. These aren't available anywhere that I could find.
So the first step is to see if I can hack together a data-interface connector.
If I can't manage this first step, then I'm just going to toss the boards in the trash.
