This program creates coil footprints in KiCAD. You simply download the files, edit main.py with your desired parameters, then run the script to get the *.kicad_mod footprint file (drop into whatever KiCAD library you want)
For a bit more backstory: I am currently working on a bigger project, the OS3M mouse (https://hackaday.io/project/187172-os3m-mouse) and am planning on using inductive sensing to tell the position of my 6DOF knob. As a PCB designer coming from Eagle, I was surprised to see no built-in coil creation support. In fact, I was surprised to see almost no support at all! The next best thing was a 7 year old github gist that was somewhat unclear on how it should be used (https://gist.github.com/JoanTheSpark/e3fab5a8af44f7f8779c). And so, I got to work writing this program.
