Minimum Viable Product:
- Mounts and space for Raspberry Pi + Power management Hat
- 7" Screen (currently DFR0678)
- GPIO pins redirected and facing the front
- Behind a door that also includes a color coded pin out on its inverse side
- An included 5V power supply
- Removable panels for A/V and COM groups on the Pi.
- Tapped hole pattern for a VESA-compliant mount on the back.
- Rugged, durable, and (most importantly) aesthetically pleasing all aluminum metal case.
- A nice, solid feeling power switch. Clicky clicky.
- Economically feasible at 25-50 units, as I don't expect larger uptake than that.
Options:
- Holder for a stylus
- Something that I thought of and forgot in an instant. Got distracted by galvanic corrosion. Thinking about it, I mean, not the actual process.
