![](https://cdn.hackaday.io/images/8316181677563337674.png)
Switched to the Microchip WLR089 LoRa module and this brings more features. Full list of improvements:
- ARM Cortex M0+ with 256 KB flash and 40KB RAM
- Dual band, 868 MHz and 915 MHz
- USB connectivity
- On-module u.FL antenna connector so no RF path needs to be on my PCB
- Switched to the Quectel LC86L GNSS module, capable of tracking GPS and also GLONASS
- Added an Analog Devices ADXL362 low-power accelerometer for activity tracking
- Added a software-controlled LED and a button
- Added an on-board I2C temperature sensor for monitoring safe operating range of battery
- Updating firmware is much easier through USB, using UF2 bootloader
- Arduino compatibility is possible, as there are ports for the SAM R34 chip in the WLR089 module
Some limitations that have been carried over from original prototype:
- LC86L module requires a much larger ground plane, thus GPS antenna performance may be significantly reduced
- LoRa antenna is packed very tightly in case close to many other components, thus performance at 868 MHz and 915 MHz is greatly reduced
Hi Mihai,
Cool update! I am playing around on a very similar set-up with WLR089. Wondering, if you are planning to make the firmware public?
Cheers,
Mark
