PokyPow
A PCB which lets you control your PC with Home Assistant
(power on, off, reset, monitor power-on state)
Public Chat
PokyPow is your companion for conveniently powering on, off, resetting, and remotely monitoring your PC’s power state. This simple ESP32-based board gives you the power of a system administrator without purchasing enterprise-grade solutions.
Build with ESPHome.
Open Source, Open Hardware.
Using standard PC power and USB headers, PokyPow makes your computer another device on your Home Assistant network. And since PokyPow uses standard ESPHome firmware, you can tweak the configuration or vet the code to ensure its trustworthiness. Whether you’re trying to save money on energy or want to have your gaming rig all fired up by the time you step in the door, PokyPow lets you control your PC like never before.
View project log
drcyberg wrote 11/30/2024 at 07:41 point
Hi!
Cool, but how and what do you attach it to? Will this device have a case?
Andrej wrote 11/30/2024 at 07:48 point
Oh my, thank for that question because it is not really obvious 😅
You plug in the usb 2.0 header into your mainboard. That way it gets power.
The pins are for front panel connectors. One side for the mainboard and the other for the case.
If you do not have an internal USB 2.0 header or your motherboard does not support always usb power on you can also use usb-c for power with a cable.
There will be no case.
But I think I will create one for 3D printing when there is demand.
