I completed the front panel today.
- Laser cut 3mm white acrylic for the front and back layers of the panel
- Attached the panels together (IPS Weld-On 3 Acrylic Plastic Cement)
- Spray Painted them with a Matt Dark Green from Rust-o-lium
- Taped down and cut a piece of cardstock for alignment, and burned away the paint leaving the white behind
- I then mounted everything.
Up next:
- Test/code the indicator lamps below the knobs
- Design and 3D print a frame to hold the lamps, marble and UVLEDs
- Cut the base piece which holds the power supplies and Geiger counter
