Blackshark Comtac headband replacement
Simple project to replace the headband of a set of Razer Blackshark headphones with the more sturdy Comtac headband
0 followers
This project replaces the headband from a pair of Blackshark 2 headphones with the headband that is commonly used on military-style Comtac headsets. We'll start by disassembling the Blacksharks, then install some 3D-printed adapter parts, then install the replacement headband.
Why would we want to replace the headband on a perfectly good pair of headphones? Well, for a few reasons, first the headband is probably the most flimsy part on any pair of headphones I've ever owned... except for military and aviation headsets. So, can we fix this? When I first saw the Blacksharks it struck me that the mounting locations were very similar to that used by military-style Comtac headsets. This pattern seems to be now used by a number of military and an increasing number of civilian headphones, as well as a world of airsoft headphones. It turns out that, yes, with a bit of work this style of headband will work perfectly, giving us a headband that is incredibly durable and easily replaceable.
Image source: Aliexpress
Why else? The stock Blackshark headband doesn't fold - meaning the headphones take up a huge amount of space, a problem easily solved by the Comtac headband. Finally, it allows for a huge range of customisation and modularity - want to use a headband cover? Military and airsoft suppliers make a huge range of colours, as well as features like a d-ring to hang your headphones of a belt or bag. Want to use a behind-the-neck headband? Easy. Want to mount your headphones to a helmet? Can-do!
blackshark_headband_studs_printable_singleset.stl
Standard Tesselated Geometry - 273.03 kB - 07/29/2023 at 10:31
Download
blackshark_headband_studs_printable.stl
Standard Tesselated Geometry - 1.07 MB - 07/29/2023 at 10:30
Download
  • 1 × Comtac style replacement headband
  • 1 × Razer Blackshark headphones
  • 1 × 3d printed parts
  • 4 × M3 x 20mm socket head bolts
  • 4 × M3 nuts
View project log
  • 1
    Step 1
    Start disassembling the headphones by removing the ear cups. Use a plastic sprudger to pry up the cups. Do your best to not snap off any of the clips
  • 2
    Step 2
    Remove the screws that hold the driver component
  • 3
    Step 3
    Remove these clips that secure the headband studs
View all 9 instructions
