Finished!
A project log for ESP-360-REMOTE
This is an all-in-one remote. It controls RF and IR appliances. It has built-in sensors and can be programmed with the TYPE-C connector.
alessandro-alfonzettiAlessandro Alfonzetti • 12/31/2022 at 14:10•0 Comments
The upgrade it's finally done!. The case is 3D printed. I found out that IR light is not affected by PLA, so it's really easy to design an enclosure. The bottom and the top part are screwed, so you only need to print the two parts without any extra comopnent. There's a blue led when the board is powered on,
