In order to use the DAC, we needed to initialize the SPI on this device as well as create a method to write the DAC values. The module uses an MCP4921 DAC IC which is at 12bit resolution. The voltage conditioners in the modules will scale the min input voltage as zero and the max output voltage as 4095. In this case 0 is -12V and 4095 is 12V making 2048 0V.
Being on the SPI Bus each DAC module is activated using the slave select PIN. We Defined these as SSX and SSY
MSP430 SPI Initialization
WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer
PM5CTL0 &= ~LOCKLPM5;//sets to 12 mh
CSCTL1 |= DCORSEL_6;//sets clockspeed
P1DIR |= BIT0 + SSX + SSY;//p1 output
P1OUT |= BIT0;//set bit 0
///SPI Int//////
P5SEL0 |= BIT1 + BIT2;
UCB0CTLW0 |= UCSWRST; // **Put state machine in reset**
UCB0CTLW0 |= UCMST+UCSYNC+UCCKPL+UCMSB; // 3-pin, 8-bit SPI master MSB
UCB0CTLW0 |= UCSSEL_2; // SMCLK
UCB0BR0 |= 0x01; // CLK / 1
UCB0BR1 = 0;
UCB0CTL1 &= ~UCSWRST;
WriteMCP Routine
void writeMCP492x(uint16_t data,uint8_t ss) {
// Take the top 4 bits of config and the top 4 valid bits (data is actually a 12 bit number)
//and OR them together
uint8_t top_msg = (0x30 & 0xF0) | (0x0F & (data >> 8));
// Take the bottom octet of data
uint8_t lower_msg = (data & 0x00FF);
// Select our DAC, Active LOW
SSOUT &= ~ss;
// Send first 8 bits
UCB0TXBUF = top_msg;
while (UCBUSY & UCB0STAT);
// Send second 8 bits
UCB0TXBUF = lower_msg;
//Deselect DAC
SSOUT |= ss;
To run faster we also set the internal clock to run at 16Mhz.
[clock lines]
CSCTL1 |= DCORSEL_6; //sets clockspeed
In the main loop after initilization, we create another loop to shine the laser directly at it's origin.
while(1){
writeMCP492x(2048, SSX);
writeMCP492x(2048, SSY);
