Seems it was just a couple of batteries that had the issue of not providing contact with each other. Not an issue with the holders themselves. But I will have to setup the holders with a through hole for the battery sensing wire for the BMS. That will make sure this will work for any battery. As it is now I will definitely have to test the batteries I want to use in these holders.
cyplesma
