I completed the debugger: it can step, run until 'RET', run until PC = address, run continuously. You can also edit the registers between steps.
Importing symbols will be implemented later.
A project log for Z80 ICE
To facilitate debugging at a low hardware level I made this adapter that turns a STM32F407ZGT6 development board into a Z80 ICE.
