I had problems with the USB UART (CH340G). It frequently disconnected under Linux.
I just looked into this these past weeks. It turned out that the USB connector became flaky and that was the cause for the frequent disconnects. I also suspected the chip wasn't supported, but a loopback test worked fine with minicom (while the connection lasted). So linux supports the CH340G.
Jacques Pelletier
