Subject: Runtime Type System on Z80: A Surprisingly Efficient Experimen
A project log for XiAleste
XiAleste Next is an 8-bit home computer, which is compatible with software for the Amstrad CPC6128 released on 13 June 1985
h2wh2w 02/15/2026 at 21:290 Comments
Hi everyone, I wanted to share the results of a recent experiment. Initially, I didn’t plan on implementing deep typing, but while developing my own assembler (ZASM), a rather compact and powerful runtime type system started to crystallize.
The Concept: We define the type hierarchy directly in the source code. The .type-descriptor macro handles all the "heavy lifting": it generates pointers to parent types, creates string names for debugging, and most importantly, constructs vtables with full inheritance support.
Source Code (Lisp-style DSL):
(defproc test-type-descriptor ()
  (declare (once) (asm-func none))
  (.type-descriptor object)
  (.type-descriptor structure)
  (.type-descriptor vec3))
The Result (Generated Listing):
The system automatically generates linked data structures. Notice how the hierarchy is preserved: vec3 correctly points to the structure parent, which in turn points to the base object.
0051:  51 00        |  DW       ; Self-reference
0053:  60 00        |  DW      ; "object" string
0055:  02           |  DB  $02                     ; Type flags/ID
0057:               | [object::vtable::new]
0057:  C3 01 00     |  JP  object::new             ; Method dispatch
007A:               | [type::def::vec3]
007A:  67 00        |  DW    ; Pointer to Parent!
0080:               | [vec3::vtable::new]
0080:  C3 05 00     |  JP  vec3::new               ; Overridden method
0083:  C3 02 00     |  JP  object::delete          ; Inherited method
Why this works well:
1. Compactness: Each descriptor occupies only a few bytes.
2. Inheritance "for free": If a method isn't overridden in a child type, the vtable simply copies the jump (JP) to the parent's implementation.
3. Runtime Reflection: Having type names available at runtime allows for robust type-checking directly on the hardware.
Next Steps: The final polish of the parse-arg logic for method argument validation. The goal is to have the assembler "slap the programmer's wrist" during compilation if they try to pass an incompatible register or type to a method.
