Great progress on the compiler! I’ve finally bridged the gap between high-level type definitions and the Z80 assembler. The compiler now handles all offset and size calculations "under the hood," injecting pure constants directly into the generated instructions.
The core benefit:
No more manual byte-counting or maintaining a mess of X_OFFSET = 2 constants. You define the structure once, and from then on, you simply refer to fields by name directly within zasm blocks.
Example implementation:
We define a type and immediately use its metadata to generate assembly:
(deftype vector (structure) ((x int16) ;; offset 0 (y int16) ;; offset 2 (z int16)))) ;; offset 4 (zasm $begin (ld @hl (size-of vector)) ;; Get total structure size (ld @hl (offset-of vector x)) ;; Get offset of field 'x' (ld @hl (offset-of vector y)) ;; Get offset of field 'y' (ld @hl (size-of vector x)) ;; Get size of the type used by field 'x' (int16) (ld [+ iy (offset-of vector y)] 10) ;; Direct write to object field via IY )
Compilation Result (Binary Dump):
8000 | begin: | 8000 | 21 06 00 | ld hl, 06h ; Total size: 3 fields * 2 bytes 8003 | 21 00 00 | ld hl, 00h ; 'x' at offset 0 8006 | 21 02 00 | ld hl, 02h ; 'y' at offset 2 8009 | 21 02 00 | ld hl, 02h ; size of int16 = 2 800C | 21 02 00 | ld hl, 02h 800F | FD 36 02 0A | ld (iy+2), 0Ah ; Indexed write (IY+2) with value 10 (0Ah)
Why this matters:
- Refactoring Resilience: If I change a field from
int16toint32, the compiler automatically updates every offset across the entire project. - Native IY/IX Support: Support for
[+ iy displacement]syntax allows us to leverage the Z80’s indexed addressing mode as natively as possible. - Readability: The code feels like a modern systems language, but the output is honest, tight assembly.
Next steps:
Implementing instances (memory allocation for objects) and beginning the port of existing code to this new workflow. Finally, I can focus on logic without turning my brain into an offset calculator!
h2w
