Implementing VTables in a Meta-Assembler: From Type Declaration to Code Generation
A project log for XiAleste
XiAleste Next is an 8-bit home computer, which is compatible with software for the Amstrad CPC6128 released on 13 June 1985
h2wh2w 02/08/2026 at 08:580 Comments
I want to share some progress on my custom meta-assembler. The core focus here is automating the creation of Virtual Method Tables (VTables). This is essential when developing drivers or system components where data structures and methods must be tightly coupled but remain easily extensible.
1. Type Declaration (Layout)
At the source level, we define the data structure and method signatures. This allows the assembler to pre-calculate field offsets and method indices for the dispatch table.
Lisp
(deftype vec3 (structure)
   ((x int16)   ;; offset 0
    (y int16)   ;; offset 2
    (z int16))  ;; offset 4
   (:methods
     (new (int16 int16) none) ;; Method ID 0
     (len () int16)))         ;; Method ID 1
2. Method Implementation
Next, we write the actual method code. By using the $ prefix, the meta-assembler automatically binds these labels to the specific type's method slots.
Lisp
            (org #x9000)
$vec3::new
            (ret)
$vec3::len
            (ret)
3. VTable Generation
The vtable command is a powerful meta-instruction. It inspects the vec3 type, locates all implemented methods, and arranges them in the correct order. It also handles "holes" (sparse tables) if certain methods aren't overridden in a hierarchy.
Lisp
            (align 16)
            (vtable position vec3)
Compilation Result (Listing)
The assembler doesn't just allocate space; it generates a functional jump table (using the jp opcode 0xC3 for the Z80).
Plaintext
9000 | --------                 | org 9000h
9000 |                          | vec3::new:
9000 | C9                       | ret
9001 |                          | vec3::len:
9001 | C9                       | ret
9002 | --------                 | align 10h
9010 | C3 00 90 00 00 00 00 00  | .vtable position, vec3, (quote default)
9010 | 00 00 00 00 00 00 00 00  |
9010 | 00 00 00 C3 01 90        |
Key Benefits:
  1. Type Safety: Manually calculating table indices is error-prone; the assembler now handles this automatically.
  2. Flexibility: If you add a method to the deftype, the VTable is rebuilt and re-aligned on the next pass.
  3. Clarity: The listing clearly shows exactly where each jump leads, making debugging significantly easier.
Next step: Implementing high-level object declarations and automating method dispatch (dynamic dispatchers).
