Hackaday.io Hackaday.io
Sign up Log in
ATtiny13 – dance lights with FFT
This project shows how to synchronize live music and lights using DSP/DFT in real-time on ATtiny13 which offers only 64B RAM / 1024B FLASH.
ukasz-podkalickiŁukasz Podkalicki
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2k views
3 comments
1k followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 3
View Gallery
2k
3
1k
12
Team (1)
  • ukasz-podkalickiŁukasz Podkalicki
Join this project's team
  • Project source code
  • Project details
completed project
hardware
attiny13 dsp fft DFT disco liGhts Party Lights Dance Lights avr led
This project is submitted for
  • The 1kB Challenge
This project was created on 12/08/2016 and last updated 6 years ago.
Description
This experimental project shows how to use ATtiny13 to synchronize live music and lights with only a few additional components required. Project uses single ADC (Analog to Digital Converter) channel for signal acquisition and some DSP (Digital Signal Processing) calculations that in real-time separate three frequency bands and make the LEDs dance in sync with the music. This project also proves that real-time DFT (Discrete Fourier Transformation) is possible on such small MCU like ATtiny13, which offers only 64B of RAM and 1024B of FLASH. Project doesn’t require any specific equipment and the parts costs are below 3$.
Details
Log In/Sign up to comment
Sign up with Github
OR
mr.jb wrote 12/10/2016 at 17:58 • point
>ADCSRA |= _BV(ADPS2)|_BV(ADPS1); // set ADC division factor 64;
>F_CPU=9600000
Are you sampling ADC with 150kHz ? and if so why ?
A fun twist of your code would be to put it inside a flash-light driver
http://flashlightwiki.com/AVR_Drivers
Łukasz Podkalicki wrote 12/10/2016 at 21:31 • point
Hi, after I read your comment I realized that I made a copy-paste
mistake. Of course, this example will work with higher sampling rate,
but it result in poor quality. Project has been tested using @1.2MHz
internal clock source. ADC division factor is set to 64 so the ADC
sampling frequency is 18750Hz (F_CPU/64). Thank you!
NOTE: “copy-paste mistake” has been fixed on both blog and github.
mr.jb wrote 12/10/2016 at 11:51 • point
NICE ! ( less is more ;-)
You should put it into 1k challenge ...
/JB
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ATtiny13 – dance lights with FFT", please tell us the reason.
Send message
Remove Member
