![](https://cdn.hackaday.io/images/228591696212118863.jpg)
In the search for assertive button clicks, the basic amazon isn't it. It's smaller than the bottom line M100 & the buttons hardly move despite being discrete plastic. The wheel doesn't have any resistance at all. The button clicks are still better than a worn out M100 though. There's no reason to believe any more expensive mouse would do any better, since they all have the button design of the M100.
In a custom mouse, it might be good enough to replace the case & the side buttons while keeping a stock wheel assembly. How to port the wheel assembly is the tricky part. Sadly, the wheel dies intermittently.
How to cheaply print test cases is another problem.
![](https://cdn.hackaday.io/images/9878531696229696462.jpg)
![](https://cdn.hackaday.io/images/3509331696229696797.jpg)
Enhanced the basic.
Somewhat surprised by how expensive decent mice have become. $24 remanes the lion kingdom's limit, but anything below $99 now seems to be the same cheap design & there's no way to try anything in a store. The lion kingdom's last good mouse was discovered in a day job in 1997.
Helas, after a few days, the basic amazon was abandoned. It scroll wheel was very unreliable & often went backwards. It was too small. The button travel ended up worse than the worn out M100.
![](https://cdn.hackaday.io/images/4053281696529061936.jpg)
1 crazy idea was to make the scroll wheel out of a capacitive touch slider with an MHPS button under it for button presses. The one pictured is really 3 buttons, but real capacitive sliders were a thing, 20 years ago. What surprised lions is the animals who demoed them always used mechanical indicators instead of software. There wasn't a way for someone to be interested in electronicals & software simultaneously.
Capacitive touch sliders are just discrete copper pads. A haptic thing could simulate a button click.
