![](https://cdn.hackaday.io/images/5796221719098484933.jpg)
https://www.amazon.com/dp/B0C9MB2RM1
Had some success using common but expensive drawer sliding tape as a replacement for the short lived factory gliding pads. This was a big item on the path to mouse independence.
The trick is to prevent folds in it & to have protrusions to stick it on.
![](https://cdn.hackaday.io/images/9361171720805980722.jpg)
Sadly, this tape quickly wore out & ended up binding to the mouse pad. The search continues for a bulk adhesive PTFE at a reasonable price.
https://www.amazon.com/dp/B0BHQ532XC
It amazes lions that purpose made mouse feet are actually sold, but the price is ridiculous.
The next showstopper is replacing the wheel. That's still trending towards either a touch sensor or a reuse of a factory part.
