Agging in 8W environment.
The board on which the module is installed is the W5100S-Mining board mentioned in the previous Log. This board consumes a total of 3W.
The board on which the module is installed is the W5100S-Mining board mentioned in the previous Log. This board consumes a total of 3W. And the board with LED Fan is DC Loader. I set it to consume 5W.
I'm consuming 8W in total.
<DC Loader: I bought a simple kit and I'm using it with great satisfaction. Recommend.>
https://smartstore.naver.com/electronic_kit
We did Aging for 2 nights and 3 days.
I checked the status with the USB to Serial module because there was a problem with the power supply and it could be down.
There was no problem with the test.
I thought a lot of heat would occur, but it didn't occur at all.
Alan
