DevKIT ESP32S3 SIM7600
ESP32-S3 is the new flagship MCU from Espressif combine Module SIM 2G/3G/4G LTE Cat4 SIM7600 from SIMCOM
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
-WiFi Modules ESP32S3FN8 – 802.11 SMD IC , Dual-Core MCU, Wi-Fi 2.4G & BLE 5.0 combo, 8 MB Octal SPI Flash
-On chips ESP32-S3 with an integrated USB Serial/JTAG Controller, it is possible to use the part of this controller that implements a serial port (CDC) to implement the serial console, instead of using UART with an external USB-UART bridge chip
SIM7600CE-M1S module: is a 2G/3G/4G communication and positioning module, supports LTE CAT4 download up to 150Mbs.
Support GPS, BeiDou, Glonass, LBS
Working voltage: 4.5-20VDC if using adapter or via USB cable or battery (3V7-4V2)
- Included in battery charging system
- Led Netlight, stt battery charging
- USB RNDIS (module SIM)
- USB Serilal/JTAG onchip (ESP32)
IO1: pin ON/OFF module SIM PWRKEY
IO2: Led user
IO3 : ADC voltage battery
IO17: RXD module sim
IO18: TXD module sim
Announced prices: 60$/pcs
Rich text editor
