A simple device for moms with high Lipase to scald their breastmilk before storage.
First thing we need is a small tea kettle to contain and heat the milk. We want a small capacity and low cost. The smallest I find is a 350 milliliter capacity - normally we're heating less than 200mL but this is close enough. These are designed like an insulated steel mug. https://www.amazon.com/dp/B08L9PG85M
For the controller, any general purpose board will suffice. I pull an Arduino out of the parts bin.
We need a relay to turn the kettle on and off. These are easy to find - I get a pack for future projects. https://www.ebay.com/itm/292280749362
I want a small fan to cool the milk off faster after the heat cycle finishes. https://www.ebay.com/itm/381774063056
I need a small 5V power supply to run the controller. I can find one in my parts bin.
I need a waterproof thermometer to track the temperature. https://www.ebay.com/itm/182671981462
Total build cost is about $45.
Thanks for your comment - excess lipase is pretty uncommon but it's just one of those things that can make parents' lives harder than it has to be. I don't know the science behind it but I read that scalding deactivates lipase so milk stays good longer - probably by breaking apart the enzyme. Other nutrients are destroyed by scalding as well, but if most of the baby's milk is fresh it's not a concern.
I honestly never heard of excess lipase, that's fascinating! Just curious, is the goal of the scalding step to denature the lipase? Seems reasonable, but just wondering.
