update time!
now the LCD screen is working, I can start displaying all the information that I want!
also this took me a suprising amount of time.
the big problems were assigning the pins correctly to the arduino in code, and to match up the hardware to software. plus that bottom resistor is for the contrast, and was meant to be a variable resistor, but i found that a 5k1 ohm resistor works just as well, giving me a crisp display, which is important for a wearable, being out in the sun most of the time, so this eleminates glare as much as possible.
my next step is to add in all of the sensors, and to make a screen for each one that i can cycle through.
And I'll take all suggestions!
Eli Ostermann
Viva Penguinos
Sverd Industries
Robert Poser
