I still need those menu buttons and maybe an IR distance sensor to tell if someone stands infront of it. The lights are, although dimmed down, quite bright and I always have to pull the plug over night. Thankfully the RTC module is pretty accurate so far :)
The LEDs also point down, so it makes sense to have the clock high and far away on a shelf somewhere, sadly.
davedarko
