The 13 Amp sockets maybe an issue, when it comes to plugging items in, on the previous design.
So reoriented the sockets by 90 degrees (facing up) and making a small hole in the tabletop for the cable gland to pass through.
In turn the hole will be hidden by the sockets enclosure and the mains cable will pass beneath the tabletop surface.
