State so far:
- Built a wooden stand for the motor
- Powered the controller and display from RD6024 PSU.
- Generate a PWM from Arduino to simulate PAS sensor.
- Blew the RD6024 PSU when the motor stopped getting power and back EMF produced a spike.
- Repaired RD6024 PSU. Added diode in series to prevent the back EMF from blowing the RD6024 again.
- Blew the display when the motor stopped getting power and back EMF produced a spike.
- Depotted the controller for analysis.
- Figured out to turn on the controller with the SW pin to run controller without display.
- Replaced soldered connections with 2.0mm female headers.
- Simulated throttle with potmeter on SPGND, SP5V, SP.
- Flashed controller with EBiCS opensource firmware.
- Blew 2 FETs due to running controller without heatsink.
