The center mount has a single 'stovepipe' that allows me to attach a pole for the feedhorn. This is the other end.
It's designed to hold an ESP-01 module so that the antenna is directly in the center of the dish.
$fn = 64;
module esp8266(){
union(){
translate([0,-4,-2])
cube([14.7,25,11], center=true);
translate([0,-12.5,6])
cube([12,8,12], center=true);
module pole(){
translate([27, 0, -21])
cylinder(d=6.40, h=30);
module holder(){
difference(){
hull(){
translate([32,0,0])
cylinder(d=4, h=10);
translate([32,5,0])
translate([32,-5,0])
translate([10,10,0])
cylinder(d=4, h=5);
translate([-10,10,0])
cylinder(d=4, h=5);
translate([-10,-20,0])
cylinder(d=4, h=5);
translate([10,-20,0])
cylinder(d=4, h=5);
esp8266();
pole();
holder();
