- RP2040 Dual Core Cortex M0+ running at up to 400MHz
- USB Type-C connector
- 2MB Flash for Firmware and Data
- Very low noise LDO regulators (separate LDO for digital circuits and separate for analog circuits), no switching regulators
- Partially pin-compatible with RP2040 (besides a few pins internally used or rearranged), extra 4 pins on each side
- Audio DAC PCM5100A, up to 32-bit output
- Very high audio signal quality and very low noise
- Dedicated Boot and Reset Buttons
- 8 channel 12-bit ADC with up to 1MS/s, with selectable 3.3V range (on-board low-noise power supply) or range up to 5V via external VREF
- Low-Pass filter on each ADC input (fMax=48 KHz) at low-impedance (100 Ohm). With 5V VREF suitable for CV (no overvoltage protection, unipolar)
- Symbols marking special pin functions on the pin headers
- 4 LEDs on shared GPIO2-5 for debugging
- ESD Protection on USB
- SWD Debug Port
Datanoise
Nick Sayer
Christoph Tack
Sagar 001
Paul Stoffregen
