Imagine your boat has an onboard computer that has access to all the information about the boat you wish it to have and displays it in the way you wish it too. For a lot of sailors it sounds futuristic and/or expensive, but this is exactly what oiyshTerminal was created for. The software part's free and open-source and the hardware can be created easily and cheaply* or also for free. The basic functionality requires only a smartphone or any system with dpkg on it. We provide the base puzzles that you can either use as is or modify to your liking.
OiyshTerminal is not a black box solution. Depending on which functionalities you choose to implement you will need to put some of the pieces of the puzzle together. This is done on purpose as we believe that everyone with minimal amount of effort, regardless of the level of technical knowledge they have, is able to do it. This approach ensures that you have at least basic knowledge of the system you are using. It will give you at minimum the ability to troubleshoot it if needed and perhaps also enough confidence to explore further and expand the system to your specific needs.
If you are not willing to put in the minimal effort this is probably not a project for you and we hope you can afford 'off the shelve solutions' and their installation fees.
yOyOeK1
lpauly
Dylan Brophy
alusion
Paige Niedringhaus
