Otdm - deb to do Node-red?
A project log for oiyshTerminal
Local server collection of IoT system with some additional futures. Works by default offline, based on .deb .npm .pipy
yoyoek1yOyOeK1 12/22/2022 at 19:360 Comments
I'm experimenting with a idea of making more automation in processes of installing flows. There is couple of topic on forum. But this is something differnt?
otdm - oiyshTerminal deb Manager
ok.
deb as a standard is a known thing. If you have simple flow it's yyy easy to make some script to make some injections to instance.
but if you need dependency's to your flow example python, opencv, not only npm stuff .... why not use something tested?
deb is used for years. by adding one word. you will ask to install on system what you need.
flow
from beginning if you have a system on this thinking process you have a one command:
$ apt install myTurboFlowExample
and if you don't have Node-red it will install it also nodejs if it's not coming as a p rebuild to your distro.
with that in mined
