It's time when you need to help me. I need your feed back about: How it's to try it from out site. Is the installation for you went well. Stuff like that. I have to paths:
Those are the manuals how to get otdm-yss running on your setup. yss Is a web interface. Now you will get only test functions page and screens manager to play with your remotes displays. I'm working on releasing more .deb's
Full description about idea is at main readme.md.
Example:
You have android device. You need to have running Node-red on something. You can set up Node-RED running in 1 line. (This command is for Termux)
$ curl https://raw.githubusercontent.com/yOyOeK1/oiyshTerminal/main/installer/run2.sh > ./run2.sh; . ./run2.sh
And you will have it running no time...
More packages is coming . ..
