Banana for scale:
None of that 3 outlet rubbish! Power strip with eight Wi-Fi controlled AC outlets.
Kopp power strip cover.stlOutlet cover STL file. Fits a Kopp POWERversal power strip.Standard Tesselated Geometry - 220.10 kB - 12/19/2022 at 13:51 |
Tasmota would probably be the right drop-in firmware for this. It already does what a power strip needs to do and much more.
because this is part of a bigger project and I intend to add an external SPI port for analog and digital IO expansion, I have however decided to go with the following:
The firmware is very simple and is available on github.
Thanks! There is a 16A in-line fuse which will never blow since the breakers will trip way faster. The relays are 10A [china-]rated, a consumer product might need further protection but I am pretty sure I won't be plugging 2 kW loads in it ;)
Tasmota would be a good drop-in firmware for the ESP32. I am however using a custom firmware because I wanted some "special" features (this is part of a bigger project for a hydroponic garden). I will update the project soon with the github links!
Nice project. What code are you running on the ESP32? Have you considered a fuse to prevent overcurrent through the relays?
