Tasmota would probably be the right drop-in firmware for this. It already does what a power strip needs to do and much more.
because this is part of a bigger project and I intend to add an external SPI port for analog and digital IO expansion, I have however decided to go with the following:
- Platformio
- Arduino STM32 framework (sans the crappy IDE)
- The ArduinoOTA library for OTA firmware support
- Standard MQTT client to talk to the world.
The firmware is very simple and is available on github.
