Structure of the system
A project log for Logial Operaiton Controller
Let's logical operation play.
higedarumaHIGEDARUMA 08/31/2023 at 07:500 Comments
We use GameControllerizer, which makes it easy to create your own controllers.
Japanese NES controllers can be controlled via D-SUB 15-pin.
コネクタ
Pins to be used include
pin
Connect the two 15-pin D-SUB connectors and the M5Stack
GameControllerizer via Grove (UART control)
When everything is set up, it will look like this.
Rich text editor
