We use GameControllerizer, which makes it easy to create your own controllers.
Japanese NES controllers can be controlled via D-SUB 15-pin.
Pins to be used include
Connect the two 15-pin D-SUB connectors and the M5Stack
GameControllerizer via Grove (UART control)
When everything is set up, it will look like this.
HIGEDARUMA
