Introduction
In today’s world, health monitoring is a major issue. Patients suffer from serious health problems as a result of a lack of proper health monitoring. There are many IoT devices available these days to monitor a patient’s health over the internet. Health professionals are also using these smart devices to keep tabs on their patients. IoT is rapidly revolutionizing the healthcare industry, with hundreds of new healthcare technology start-ups using patient health monitoring system
In this project, we will create an IOT-based Health Monitoring System that will record the patient’s pulse rate and surrounding temperature. This system not only record these data but also update them in IOT platform. The IOT platform used in this project is Thing Speak. Thing Speak is an open-source Internet of Things (IoT) application and API to store and retrieve data from things using the HTTP protocol over the Internet or via a Local Area Network.
We have already done some similar projects you can view them by clicking the following link
IOT BASED PARALYZED HEALTH CARE MONITORING AND FACILITATION
PCB Manufacturer
PCBWAY is quite professional in the field of PCB manufacturing; you can try their services at extremely low prices, Only 5 dollars for 10 PCBs , besides this the new members also get a 5 Dollars bonus.
You can now upload the Gerber File to the Website and place an order. The PCB quality is superb & high standard. That is why most of people trust PCBWAY for PCB & PCBA Services.
You Will get FREE prototype pcb from PCBWAY. So do not be late to register and place your first order from PCBWAY
If you want to order pcb from PCBWAY . CLICK IN THE LINK BELOW:
Some Sample PCB ‘ S From PCBWAY
Manufacturing Files
If you don’t want to assemble the circuit on breadboard and you want PCB for the project, then here is the PCB for you.
Gerber Files
Download gerber files
Gerber_PCB_Patient-Health-MonitoringDownload
Bill Of Material
SN | COMPONENTS NAME | DESCRIPTION | QUANTITY | ![]() |
1 | Arduino Nano Board | microcontroller | 1 | https://amzn.to/3EBaQFT |
2 | LCD Display | 16x2 LCD Display | 1 | https://amzn.to/3hXYRdV |
3 | Potentiometer | 10K | 1 | https://amzn.to/3tX7vMD |
4 | ESP8266-01 | Wifi Module | 1 | https://amzn.to/3EwkTfD |
5 | Pulse Sensor | PulseSensor.com | 1 | https://amzn.to/3OAxxPb |
6 | LM35 | Temperature Sensor | 1 | https://amzn.to/3XvVaN2 |
7 | Connecting wires | jumper wire | some | https://amzn.to/3tX7PLl |
8 | Breadboard | Normal | 1 | https://amzn.to/3Vlefzw |
9 | 2K Resistor | tht | https://amzn.to/3EudLQO | |
10 | 1K Resistor | tht | https://amzn.to/3V5Yblo | |
11 | LED 5mm | Any Color | 1 | https://amzn.to/3AHaTih |
Block Diagram
This is a simple block diagram demonstrating the IoT Based Patient Health Monitoring System with ESP8266 and Arduino. BPM and environmental temperature are measured by the pulse sensor and the LM35 temperature sensor, respectively. The code is processed by the Arduino and displayed on a 16*2 LCD display. The ESP8266 Wi-Fi module connects to the internet and sends data to an IoT device server. The IoT server used here is Thing speak. Finally, the data can be accessed from anywhere in the world by connecting to the Thing speak channel.
What is a Pulse sensor?
A pulse wave is the change in the volume of a blood vessel that occurs when the heart pumps blood, and a detector that monitors this volume change is called a pulse sensor. The Pulse Sensor is an Arduino-compatible heart-rate sensor. Students, artists, athletes, makers, game and mobile developers who want to easily incorporate live heart-rate data into their projects can use it. It essentially combines a basic optical heart rate sensor with amplification and noise cancellation circuitry, allowing for quick and easy pulse readings.
Pulse sensor top and back view
There is also a LED in the center of this sensor module which helps in detecting the heartbeat. Below the LED, there is a noise elimination circuitry that is supposed to keep away the noise from affecting the readings.
LM35 Temperature Sensor:
LM35 is a temperature sensor that outputs an analog signal which is proportional to the instantaneous temperature. The output voltage can easily be interpreted to obtain a temperature reading in Celsius. The advantage of lm35 over thermistor is it does not require any external calibration. The coating also protects it from self-heating.
ESP8266
The ESP8266 is a simple and inexpensive device for providing internet connectivity to your projects. Because the module can function as both an access point (which can create a hotspot) and a station (which can connect to Wi-Fi), it can easily fetch data and upload it to the internet, making the Internet of Things as simple as possible. It can also retrieve data from the internet via APIs, allowing your project to access any information available on the internet, making it smarter. Another intriguing feature of this module is that it can be programmed using the Arduino IDE, making it much more user-friendly.
Pin 1: Ground: Connected to the ground of the circuit
Pin 2: Tx/GPIO – 1: Connected to Rx pin of programmer/uC to upload program
Pin 3: GPIO – 2: General purpose Input/output pin
Pin 4 : CH_EN: Chip Enable/Active high
Pin 5: Flash/GPIO – 0: General purpose Input/output pin
Pin 6 : Reset: Resets the module
Pin 7: RX/GPIO – 3: General purpose Input/output pin
Pin 8: Vcc: Connect to +3.3V only
Circuit Diagram
The circuit diagram of IOT based Patient Health Monitoring system is shown in the figure below. If you are doing the same project then assemble the circuit as shown in the figure below:
- Connect Pulse Sensor output pin to A0 of Arduino and other two pins to VCC & GND.
- Connect LM35 Temperature Sensor output pin to A1 of Arduino and other two pins to VCC & GND.
- Connect the LED to Digital Pin 7 of Arduino via a 220-ohm resistor.
- Connect Pin 1,3,5,16 of LCD to GND.
- Connect Pin 2,15 of LCD to VCC.
- Connect Pin 4,6,11,12,13,14 of LCD to Digital Pin12,11,5,4,3,2 of Arduino.
- The RX pin of ESP8266 works on 3.3V and it will not communicate with the Arduino when we will connect it directly to the Arduino. So, we will have to make a voltage divider for it which will convert the 5V into 3.3V. This can be done by connecting the 2.2K & 1K resistor. Thus the RX pin of the ESP8266 is connected to pin 10 of Arduino through the resistors.
- Connect the TX pin of the ESP8266 to pin 9 of the Arduino.
Here is another version of the Schematic designed using EasyEDA software. Instead of using Arduino UNO, you can use Arduino Nano for this project.
Setting Up Thingspeak
ThingSpeak provides very good tools for IoT-based projects. The ThingSpeak website allows you to monitor data and control your system over the Internet using channels and web pages provided by ThingSpeak. Therefore, you must first log into ThingSpeak. Please access https:
Create an account at thingspeak.com.
Then create a new channel and set up what you want. The tutorial in the video below. Follow the video for more clarification.
Then create the API keys. This key is required for programming modifications and setting your data.
Then upload the code to the Arduino UNO by assembling the circuit shown above. Open the serial monitor and it will automatically connect to Wi-Fi and set up everything.
Now click on channels so that you can see the online data streaming, i.e IoT Based Patient Health Monitoring System using ESP8266 & Arduino as shown in the figure here.
Source Code
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#include <SoftwareSerial.h>
float pulse = 0;
float temp = 0;
SoftwareSerial ser(9,10);
String apiKey = "OO707TGA1BLUNN12";
// Variables
int pulsePin = A0; // Pulse Sensor purple wire connected to analog pin 0
int blinkPin = 7 ; // pin to blink led at each beat
int fadePin = 13; // pin to do fancy classy fading blink at each beat
int fadeRate = 0; // used to fade LED on with PWM on fadePin
// Volatile Variables, used in the interrupt service routine!
volatile int BPM; // int that holds raw Analog in 0. updated every 2mS
volatile int Signal; // holds the incoming raw data
volatile int IBI = 600; // int that holds the time interval between beats! Must be seeded!
volatile boolean Pulse = false; // "True" when User's live heartbeat is detected. "False" when nota "live beat".
volatile boolean QS = false; // becomes true when Arduoino finds a beat.
// Regards Serial OutPut -- Set This Up to your needs
static boolean serialVisual = true; // Set to 'false' by Default. Re-set to 'true' to see Arduino Serial Monitor ASCII Visual Pulse
volatile int rate[10]; // array to hold last ten IBI values
volatile unsigned long sampleCounter = 0; // used to determine pulse timing
volatile unsigned long lastBeatTime = 0; // used to find IBI
volatile int P = 512; // used to find peak in pulse wave, seeded
volatile int T = 512; // used to find trough in pulse wave, seeded
volatile int thresh = 525; // used to find instant moment of heart beat, seeded
volatile int amp = 100; // used to hold amplitude of pulse waveform, seeded
volatile boolean firstBeat = true; // used to seed rate array so we startup with reasonable BPM
volatile boolean secondBeat = false; // used to seed rate array so we startup with reasonable BPM
void setup()
lcd.begin(16, 2);
pinMode(blinkPin,OUTPUT); // pin that will blink to your heartbeat!
pinMode(fadePin,OUTPUT); // pin that will fade to your heartbeat!
Serial.begin(115200); // we agree to talk fast!
interruptSetup(); // sets up to read Pulse Sensor signal every 2mS
// IF YOU ARE POWERING The Pulse Sensor AT VOLTAGE LESS THAN THE BOARD VOLTAGE,
// UN-COMMENT THE NEXT LINE AND APPLY THAT VOLTAGE TO THE A-REF PIN
// analogReference(EXTERNAL);
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" Patient Health");
lcd.setCursor(0,1);
lcd.print(" Monitoring ");
delay(4000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Initializing....");
delay(5000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Getting Data....");
ser.begin(9600);
ser.println("AT");
delay(1000);
ser.println("AT+GMR");
delay(1000);
ser.println("AT+CWMODE=3");
delay(1000);
ser.println("AT+RST");
delay(5000);
ser.println("AT+CIPMUX=1");
delay(1000);
String cmd="AT+CWJAP=\"Alexahome\",\"98765432\"";
ser.println(cmd);
delay(1000);
ser.println("AT+CIFSR");
delay(1000);
// Where the Magic Happens
void loop()
serialOutput();
if (QS == true) // A Heartbeat Was Found
// BPM and IBI have been Determined
// Quantified Self "QS" true when arduino finds a heartbeat
fadeRate = 255; // Makes the LED Fade Effect Happen, Set 'fadeRate' Variable to 255 to fade LED with pulse
serialOutputWhenBeatHappens(); // A Beat Happened, Output that to serial.
QS = false; // reset the Quantified Self flag for next time
ledFadeToBeat(); // Makes the LED Fade Effect Happen
delay(20); // take a break
read_temp();
esp_8266();
void ledFadeToBeat()
fadeRate -= 15; // set LED fade value
fadeRate = constrain(fadeRate,0,255); // keep LED fade value from going into negative numbers!
analogWrite(fadePin,fadeRate); // fade LED
void interruptSetup()
// Initializes Timer2 to throw an interrupt every 2mS.
TCCR2A = 0x02; // DISABLE PWM ON DIGITAL PINS 3 AND 11, AND GO INTO CTC MODE
TCCR2B = 0x06; // DON'T FORCE COMPARE, 256 PRESCALER
OCR2A = 0X7C; // SET THE TOP OF THE COUNT TO 124 FOR 500Hz SAMPLE RATE
TIMSK2 = 0x02; // ENABLE INTERRUPT ON MATCH BETWEEN TIMER2 AND OCR2A
sei(); // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED
void serialOutput()
{ // Decide How To Output Serial.
if (serialVisual == true)
arduinoSerialMonitorVisual('-', Signal); // goes to function that makes Serial Monitor Visualizer
else
sendDataToSerial('S', Signal); // goes to sendDataToSerial function
void serialOutputWhenBeatHappens()
if (serialVisual == true) // Code to Make the Serial Monitor Visualizer Work
Serial.print("*** Heart-Beat Happened *** "); //ASCII Art Madness
Serial.print("BPM: ");
Serial.println(BPM);
else
sendDataToSerial('B',BPM); // send heart rate with a 'B' prefix
sendDataToSerial('Q',IBI); // send time between beats with a 'Q' prefix
void arduinoSerialMonitorVisual(char symbol, int data )
const int sensorMin = 0; // sensor minimum, discovered through experiment
const int sensorMax = 1024; // sensor maximum, discovered through experiment
int sensorReading = data; // map the sensor range to a range of 12 options:
int range = map(sensorReading, sensorMin, sensorMax, 0, 11);
// do something different depending on the
// range value:
switch (range)
case 0:
Serial.println(""); /////ASCII Art Madness
break;
case 1:
Serial.println("---");
break;
case 2:
Serial.println("------");
break;
case 3:
Serial.println("---------");
break;
case 4:
Serial.println("------------");
break;
case 5:
Serial.println("--------------|-");
break;
case 6:
Serial.println("--------------|---");
break;
case 7:
Serial.println("--------------|-------");
break;
case 8:
Serial.println("--------------|----------");
break;
case 9:
Serial.println("--------------|----------------");
break;
case 10:
Serial.println("--------------|-------------------");
break;
case 11:
Serial.println("--------------|-----------------------");
break;
void sendDataToSerial(char symbol, int data )
Serial.print(symbol);
Serial.println(data);
ISR(TIMER2_COMPA_vect) //triggered when Timer2 counts to 124
cli(); // disable interrupts while we do this
Signal = analogRead(pulsePin); // read the Pulse Sensor
sampleCounter += 2; // keep track of the time in mS with this variable
int N = sampleCounter - lastBeatTime; // monitor the time since the last beat to avoid noise
// find the peak and trough of the pulse wave
if(Signal < thresh && N > (IBI/5)*3) // avoid dichrotic noise by waiting 3/5 of last IBI
if (Signal < T) // T is the trough
T = Signal; // keep track of lowest point in pulse wave
if(Signal > thresh && Signal > P)
{ // thresh condition helps avoid noise
P = Signal; // P is the peak
} // keep track of highest point in pulse wave
// NOW IT'S TIME TO LOOK FOR THE HEART BEAT
// signal surges up in value every time there is a pulse
if (N > 250)
{ // avoid high frequency noise
if ( (Signal > thresh) && (Pulse == false) && (N > (IBI/5)*3) )
Pulse = true; // set the Pulse flag when we think there is a pulse
digitalWrite(blinkPin,HIGH); // turn on pin 13 LED
IBI = sampleCounter - lastBeatTime; // measure time between beats in mS
lastBeatTime = sampleCounter; // keep track of time for next pulse
if(secondBeat)
{ // if this is the second beat, if secondBeat == TRUE
secondBeat = false; // clear secondBeat flag
for(int i=0; i<=9; i++) // seed the running total to get a realisitic BPM at startup
rate[i] = IBI;
if(firstBeat) // if it's the first time we found a beat, if firstBeat == TRUE
firstBeat = false; // clear firstBeat flag
secondBeat = true; // set the second beat flag
sei(); // enable interrupts again
return; // IBI value is unreliable so discard it
// keep a running total of the last 10 IBI values
word runningTotal = 0; // clear the runningTotal variable
for(int i=0; i<=8; i++)
{ // shift data in the rate array
rate[i] = rate[i+1]; // and drop the oldest IBI value
runningTotal += rate[i]; // add up the 9 oldest IBI values
rate[9] = IBI; // add the latest IBI to the rate array
runningTotal += rate[9]; // add the latest IBI to runningTotal
runningTotal /= 10; // average the last 10 IBI values
BPM = 60000/runningTotal; // how many beats can fit into a minute? that's BPM!
QS = true; // set Quantified Self flag
// QS FLAG IS NOT CLEARED INSIDE THIS ISR
pulse = BPM;
if (Signal < thresh && Pulse == true)
{ // when the values are going down, the beat is over
digitalWrite(blinkPin,LOW); // turn off pin 13 LED
Pulse = false; // reset the Pulse flag so we can do it again
amp = P - T; // get amplitude of the pulse wave
thresh = amp/2 + T; // set thresh at 50% of the amplitude
P = thresh; // reset these for next time
T = thresh;
if (N > 2500)
{ // if 2.5 seconds go by without a beat
thresh = 512; // set thresh default
P = 512; // set P default
T = 512; // set T default
lastBeatTime = sampleCounter; // bring the lastBeatTime up to date
firstBeat = true; // set these to avoid noise
secondBeat = false; // when we get the heartbeat back
sei(); // enable interrupts when youre done!
}// end isr
void esp_8266()
// TCP connection AT+CIPSTART=4,"TCP","184.106.153.149",80
String cmd = "AT+CIPSTART=4,\"TCP\",\"";
cmd += "184.106.153.149"; // api.thingspeak.com
cmd += "\",80";
ser.println(cmd);
Serial.println(cmd);
if(ser.find("Error"))
Serial.println("AT+CIPSTART error");
return;
String getStr = "GET /update?api_key=";
getStr += apiKey;
getStr +="&field1=";
getStr +=String(temp);
getStr +="&field2=";
getStr +=String(pulse);
getStr += "\r\n\r\n";
// send data length
cmd = "AT+CIPSEND=4,";
cmd += String(getStr.length());
ser.println(cmd);
delay(1000);
ser.print(getStr);
Serial.println(getStr); //thingspeak needs 15 sec delay between updates
delay(3000);
void read_temp()
int temp_val = analogRead(A1);
float mv = (temp_val/1024.0)*5000;
float cel = mv/10;
temp = (cel*9)/5 + 32;
Serial.print("Temperature:");
Serial.println(temp);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("BPM :");
lcd.setCursor(7,0);
lcd.print(BPM);
lcd.setCursor(0,1);
lcd.print("Temp.:");
lcd.setCursor(7,1);
lcd.print(temp);
lcd.setCursor(13,1);
lcd.print("F");
Youtube
Full Project On Website :
https://electronicsworkshops.com/2022/11/14/patient-health-monitoring-using-esp8266-arduino/
