Hardware
LRAD are Genasys proprietary devices, so there is no access to details and circuits. However, there is a YouTube video where an audio specialist bought one of this devices for study. What did he find? Basically, a speaker horn array with a robust frame, good amplification and specifically designed audios to generate ear discomfort.
In the local market and at reasonable prices I was able to get an outdoor speaker horn and a matching mono amplification board. For detection and audio playback I decided to use a Raspberry Pi, since it has a decent camera, an audio output and easy integration with the Machine Learning platform Edge Impulse.
The complete list of materials is:
- Raspberry Pi 3
- Raspberry Pi cam
- Outdoor speaker horn
- Mono amp Tpa3118
- 12v power supply for the amp
- 5v power supply for Raspberry
- DFRobot LED button
- Miniplug cable
- 7 segment display TM1637
- 1 channel relay module
LRAD circuit
- TM1637 display CLK pin to GPIO 3, DIO pin to GPIO2, GND to GND, VCC to VCC
- Relay pin to GPIO 4, GND to GND and VCC to VCC. Then Relay NC and Signal in the middle of positive to 12V and amp power +. Negative of 12V to GND of amp power.
- 5V power supply to the microUSB for the Raspberry, but with + intercepted by DfRobot Led button.
- Speaker to amp audio output.
- Raspberry 3.5mm audio Output to amp Input (consider that only the 2 point parts are used, since the same connector is used for video. In my case it worked to use a stereo miniplug not totally inserted
Connect audio to X segments of the 3.5 jack.
LRAD Enclosure
I’ve found an old PC removable HD tray big enough for all the components of this project. Then I’ve designed a small 3d part to hold 7 segment display and DFRbot Led button.
You can download this part at https://cults3d.com/en/3d-model/gadget/lrad-panel
Machine learning human detection
Lots of people passes by and it would be bad to shock a neighbor walking the dog.
If the sound cannon won’t detect people, could it detect certain actions of the people? Like fights, which actually happens almost every day. The interesting part is that I don’t even need to take hundreds of pictures since there is a dataset with human actions in the AI community Hugging Face.
I wrote a Python script to download 2 actions from this dataset: "people sitting" and "people fighting"
I have created a new project at Edge Impulse platform (free for developers) and uploaded the pictures, I trained a model and exported to an EIM file.
Audio files
A brave man confronted a police grade LRAD and uploaded the video to YouTube. I downloaded the file, extracted the audio, processed this audio with Audacity app, replicated in time and exported the file as.WAV
Raspberry Pi Configuration
For the Raspberry Pi, I have executed this commands after installing the non desktop version of Raspi OS.
sudo apt-get install python3-pip
sudo apt install git
pip install picamera
sudo apt install python3-opencv
sudo apt-get install libatlas-base-dev libportaudio0 libportaudio2 libportaudiocpp0 portaudio19-dev
git clone https://github.com/edgeimpulse/linux-sdk-python
sudo python3 -m pip install edge_impulse_linux -i https://pypi.python.org/simple
sudo python3 -m pip install numpy
sudo python3 -m pip install pyaudio
I have uploaded the LRAD Python script, WAV file and EIM Machine Learning model (LRAD software)
I have assigned 744 execute permissions to the EIM and added the script to cronjob.
crontab -e
@reboot sudo python /home/pi/lrad4.py > /home/pi/lradlog.txt
Then reboot with sudo reboot
The LRAD script is autoexecuted. In the 7 segment display a greeting will be displayed, then the detection percentage and the trigger notice.
All the console output of the LRAD script are logged into lradlog.txt file
Some code settings to modify:
# EIM file name in case you use a new version
model = "domestic-ml-lrad-2-linux-armv7-v8.eim"
# fighting percentage
detectionLimit=0.75
# GPIO pin for the relay
relayPin=4
