Hi! Just want to show a little update on the Ludus first prototype.
I've seen that this size is too big to play comfortable. That it's why I'm going to move to a 5" screen instead of 7" for V2.
Also, I'm going to design a pcb to join all parts together and make it easier to assembly as a kit. Hope to have enough space for a 3.7V 6600 mAh 3 cells lipo battery.
I'm thinking about using standard replacement parts for the buttons (snes style, both the cross direction and abxy buttons) and add a analog styck from the psp 1000 (which it's really low profile)
If you have any feedback, I'll really appreciate that.
Greetings!
Luis Diaz
I'd say add 5mm between buttons and display, it looks a bit too close - otherwise very cool project!
Thanks for the feedback! It's one of the things that I've un mind.
