Thoughts about future
01/17/2017 at 19:37 • 0 commentsIn order to create a better device, I'm going to change the left side buttons pcb for a custom made board.
For the D-Pad I'm going to use the alps skquaaa010 4 way navigation switch, which is something close to an analog stick but still button-like, so, it's more .... "retro".
Also, in the same pcb I'm going to add 4 tactile buttons to work as (probably) start/select + 2 user defined configurations.
Also, I'm planning to add a audio amplifier and a speaker if there is enough space.
Greetings!
Updates
12/11/2016 at 11:32 • 0 commentsDec 11 2016: First iteration of the top case
