STM32 based extented Kalman filter
A project log for Fin Controlled Active Rocket Stabilization System
Vertical flight using Canard Fin based Controls And With IMU data from the AHRS system
electronxElectronx 01/11/2023 at 20:382 Comments
I was able to develop an extended kalman filter based imu firmware on stm32.More on the way.
Rich text editor
Loganmadon12 wrote 02/09/2024 at 10:29 point
anyway i could see the code
Gravis wrote 01/17/2023 at 13:38 point
tips from experience:
* Be sure that your sensors are sending data fast enough so that you avoid oversampling your data which will completely negate your kalman filter.
* Be sure that you aren't exceeding the range of what your sensors can measure.
* Record your flight data for post flight analysis. This is the most import part!
