Unfortunatelly the new Tips, mechanically are not compatible! Look at the compare picture bellow. If you use it without Case it works but in a Case for older Version you cannot use it! The diameter of the metall pice is 9.45mm and the old one is 9mm! The length of the metall pice is 14mm and the old one is 10.5mm!
http://www.global-motions.com/New-Weller-RT-Tips.jpg
