Yeah! I find the last piece of my 30 SBC, mounted them together with hexagonal brass positioning column.
( M3 x 20mm column x 4mm screw )
The 4mm screw is enough, but it's almost too short. 6mm would be better.
A project log for Photogrammetry Rig with 30 Sony Cameras
Use Sony Camera Remote API to control 30 cameras, including NEX 5R, NEX 5T, NEX 6, A5100, or more. Build Control Panel UI and Hardware Rig.
