The Ferrari 328 and 412 models in the 1980’s use a heater valve (p/n 126324) that is operated by an electronic control motor. After 30-40 years, many of these valves are beginning to leak, and the original heater valve is no longer available. The original 126324 valve (part number 34 in diagram below) is a unique shape and is connected to the control motor by a bracket (part number 42) and linkage (part number 35). The valve/bracket/linkage/motor assembly is then attached to the bracket numbered 15, which secures it in the vehicle.
In order to replace these valves and keep all original functionality, a replacement valve was selected that has the correct inlet and outlet hose sizes and orientation, correct actuator orientation and direction of rotation, and wide availability (to prevent it from also becoming obsolete). The original assembly and the replacement valve were modeled in Autodesk Inventor, and the original valve and bracket were replaced with the new valve. A new bracket was designed to support the replacement valve in the original location using original mounting points. Thus, the replacement valve and new bracket will directly replace the original valve and bracket.
A two-piece coupling was developed to connect the new valve to the control motor, allowing one piece to screw onto the valve shaft, while the other piece slides onto the motor's square shaft. The linkage is designed to allow slight misalignment without creating binding.
A rendering of the completed bracket and valve assembly is shown below (the coupling is also depicted connected to the bottom of the valve, but is mostly obscured by the bracket). The brackets and couplings were constructed of Nylon PA12 using the HP MultiJet Fusion process. The completed valves were assembled and tested and performed just like the original valve, but without the leakage.
Rob Kuelbs
Jarrod
Jesse Tolvanen
Alex Carpenter
