Blackberry Pi
A hand held raspberry pi zero 2 powered device.
This is my hand held raspberry pi project.
The case is designed by me and is ongoing.
I use Tinkercad to design it. I 3D printed the parts on my Creality CR10S. The design is modular. The keyboard is removable by sliding it off. I plan to make different modules that can be swapped depending on what you want to do. A keyboard for typing, a controller for games, and a couple ideas i had. I plan to sell the housings.
  • 1 × Raspberry Pi Zero 2W A small SBC
  • 1 × Pimoroni hyperpixel 4.0 square with touch A really nice lcd screen with touch
  • 1 × BBQ20KBD keyboard A BlackBerry keyboard from Solderparty that turns it into a USB keyboard and mouse
  • 1 × MH-CD42 charge/discharge board A small board that handles the battery charging and also has a constant 5 volt output
  • 1 × USB-C breakout board A USB-C breakout board that has resistors on cc1 and cc2 so i can power it from my PD chargers
View all 15 components
Alex0261 wrote 06/27/2024 at 22:22 point
please try to make one to work with rpi 5 just keep 2 usb ports im sure u will make a sick one
Alex0261 wrote 06/27/2024 at 22:13 point
I would love to see that slim version specially running kali linux and rpi5  for more ram
pdrift86 wrote 02/24/2023 at 03:06 point
I have actually redesigned this project and it now has a pi4 in it. I removed the usb and ethernet ports to slim it down. I will update this project this weekend.
Yes the pimoroni drivers can be a pain. My suggestion is to start with a fresh install of raspberry pi os.
ombudsman wrote 02/23/2023 at 23:03 point
Awesome, really nice hand/pocket pc. I was trying to build the same project but with a rpi 4. Sadly I have a huge problem with drivers/hardware for the pimoroni 4.0 sq touch screen. What version of raspbian are currently running on rpi zero 2w board ?
